dedicated circuit breaker won't turn back on
Old 12-27-13, 02:00 PM
L
The only thing this circuit covers is the washing machine.
The plug is in the wall, basically about three feet from the box.
Last I heard, everything was fine, but now the circuit has tripped and won't reset.
The washing machine is not running, so there shouldn't be anything on the circuit.
But I tried turning it off, and then on again, and do deal.
Help?
Old 12-27-13, 02:22 PM
Received 1 Upvote on 1 Post
Sounds like a dead short.
Shut the breaker off, remove the wire and see if it can be reset. If so then there's a ground touching a hot wire some place or the outlets trash.
Old 12-27-13, 02:26 PM
P
Received 2,310 Upvotes on 2,055 Posts
I would turn off that breaker and check for a short. At first I would focus on the receptacle but it could be anywhere. Luckily it's very close to the panel so it should be easy to find.
If you don't find a short try a different breaker. The panel probably has another one of the same amperage that you could temporarily hook the washer's wire up to. If the test breaker trips there is probably a short somewhere. If the test breaker does not trip the original one may be bad.
