Fuse Panel Amperage Question for Electric Cooktop
Old 12-28-13, 01:23 PM
R
Question Fuse Panel Amperage Question for Electric Cooktop
I need to replace my electric cooktop. My fusebox has two 30-amp cartridge fuses dedicated to "range." The current cooktop (made in 1994) is only 29-amp, but all cooktops nowadays require 40 amps. The wall oven and cooktop are both on this same circuit (when I pull the switch, both stop working).
The fuse panel diagram chart says "31-60 amp fuses" for the "range switch" so are these two cartridge fuses combined on the same circuit to equal 60 amps; or are they more likely 30 amps each (one for oven and one for cooktop).
The wall oven is rated at only 20 amps.
Large image of fuse box: http://hoffmancreations.com/DSC00110.JPG
Old 12-28-13, 01:34 PM
pcboss's Avatar
Received 200 Upvotes on 175 Posts
Each leg is fused at whatever the fuse rating is. You do not add the two together.
Old 12-28-13, 01:37 PM
P
You need two fuses for 240 volts so if there are only two 30 amp fuses that is what you have, 30 amps. Assuming #10 wire the fuses can't be increased with out changing the feed.
You are going to have to run 6-3 NM-b (black, red, white plus ground) to a junction box between the stove and oven* and change to 60 amp fuses. You will run a feed for a stove receptacle (NEMA 14-50r) from there and and connect the whip from the oven to the junction box.
*Junction box should be close enough to the oven for the whip to reach.
