Single Circuit Switched Neutral Transfer Switch
Old 12-30-13, 06:13 AM
I know this isn't a product recommendation forum, but maybe we can look at this as a "does this product exist" question?
I am hooking up a transfer panel for a Generac XP8000E. I am using the 30A 240 v outlet, an outdoor power inlet box, and a 30A switched neutral transfer panel.
The generator is rated 33.3A/41A Max. I was thinking that, in order to maximize the power I can get during any motor startup situations, that I can use one of the 120V 15A plugs, and wire in a separate switch for the furnace blower.
My problem is that I can't find a single circuit transfer switch that switches the neutral. Does this exist, or will I need to make my own?
Old 12-30-13, 07:30 AM
P
Received 14 Upvotes on 11 Posts
EZ Generator switch. There are videos in the link, showing installation.
EZ Generator Switch | Manual Transfer Switch
Old 12-30-13, 07:31 AM
Tolyn Ironhand's Avatar
Received 893 Upvotes on 754 Posts
***EDIT Misunderstood question *****
Old 12-30-13, 07:59 AM
Seems sketchy. Does it have a center off? I would think that a center off is required for it to be to code
Old 12-30-13, 08:51 AM
P
Answered in the other forum.
