Cant find a switch for the job i am doing
Old 12-30-13, 08:46 AM
A
Hello everyone, first time poster here. I am having trouble finding a switch that I need for a control panel I am building. I would like the switch to be a 22mm hole.
Basically I need a 2 position switch that I can use to select between 2 different inputs to 1 common output. More specifically I am using 2 auber instrument temperature controllers to control 1 SSR via 12VDC and would like to switch the SSR control between the 2 temp controller outputs. I also need to turn on a 120v light for the selected controller.
Now I know I can use a 3 position 2NO switch to select between controllers but I would rather not have a center off position, I want 1 controller selected at all times. Also are there switches with DPST that I can run 12vdc on 1 pole and 120vac on the other? This is my ideal switch. If need be I don't mind using a switch to control an external relay to accomplish my goal.
But as for the switch itself, im not sure what to look for ie: 2nc contacts or 2no? I can pretty much only find 2 position switches with 1no contact. but that leaves me with a basic on/off switch right? when I need an ON/ON switch essentially...
Any help you can give will be appreciated, sorry for the long post.
Old 12-30-13, 09:48 AM
Tolyn Ironhand's Avatar
Received 902 Upvotes on 762 Posts
Welcome to the forums!
A switch that has two inputs and one common would be a single pole, double throw switch. (SPDT)
I would not mix high voltage (120v) and low voltage together. Use a relay to switch the high voltage.
Old 12-30-13, 10:44 AM
A
Ok how would I power the relay? My output from the temp controller would be 12vdc but fast switching hence the SSR. where would I get my control current from to power the 120v relay? I guess I would have to use a DPDT switch with a separate dc power supply to one set of contacts?...but then wouldn't I need 2 separate relays to power the 2 lights?
Old 12-30-13, 11:39 AM
W
Received 1 Upvote on 1 Post
They make 22mm, 2 position selector switches. You can add as many contacts to selector switches as you need. They make NO, NC and NO/NC. Just depends on how deep your enclosure is.
Try Wolf Automation or Allied Electronics.
Old 12-30-13, 12:41 PM
F
Received 39 Upvotes on 31 Posts
Grainger and Automation Direct are two more sources for 22mm operators and contact blocks.
