Reload this Page >
Insight needed for wiring 2 fixtures and 2 switches to 1 source
Old 12-31-13, 11:57 AM
Hi all,
I am new to electrical work and am replacing a bathroom fan which is on a switch loop. There is also a light fixture on another switch loop connected to the same power source. The fan and light operate on separate switches. During the process, I removing some of the wiring with plans to put it back but now after putting it back, i am not getting the results I hoped for and I hoping you can help.
Currently, I have the fixtures and switches wired as described in the attached diagram. Both the fan and light fixtures are physically next to each other and the 2 switches are in the same switch box. The power source goes to the fixtures. All wire connections are in the same junction box next to the fixtures.
When I flip on switch 1, the light flickers then goes out while the fan goes on and stays on. When I flip on switch 2, the fan goes on and the light stays off.
If I flip on switch 1 and leave it on, then flip switch 2 on and off rapidly, the light will flicker on and off.
I am expecting switch 1 to only control the light and switch 2 to only control the fan.
I am hoping to avoid calling in an electrician so any insight you can offer would be very appreciated.
Thanks
Old 12-31-13, 01:11 PM
Received 4,154 Upvotes on 3,730 Posts
The white wires that are carrying the "always" live power to the switch should be recolored or remarked so that they aren't white. I use blue but red is a good color too.
Your diagram is shown correctly. Your diagram is most likely how you wanted to wire the circuit.... but not how it's actually done.
Old 12-31-13, 04:41 PM
pcboss's Avatar
Received 210 Upvotes on 181 Posts
The diagram is correct. ..
Old 01-01-14, 09:17 AM
Thanks
Thanks guys! An assumption I made that I didn't even realize was an assumption is what got me.
Turns out I had accidentally identified the power source as one of the switch cables. I corrected that mistake and now I am good to go!
Old 01-01-14, 09:22 AM
pcboss's Avatar
Glad you figured it out. Thanks for the followup.
