Need help with older electric baseboard wiring Please
Old 12-31-13, 02:03 PM
Hello all,thanks for reading
I just purchased an older Sentinel AB7 electric baseboard heater to use in a small room ,little confused on the wiring.It reads on the panel 277vac 17 amps.Figured I would need to purchase a double pole 20 amp breaker using 12/3 wire.When I cracked open the panel there are only 2 red wires,a ground on the casing and no neutral wire just the 2 red.
Are both these red wires hots that go to the breaker?
I attached pics,hopefully someone can help me
thanks very much for your time,really appreciate it
Old 12-31-13, 02:23 PM
277 volts is commercial not residential. If this is a house you do not have 277 volts. If no fan it might work to some extent on 240 volts but you will give off less heat.
Neutral is only used for 120 volt devices.
Old 12-31-13, 06:05 PM
CasualJoe's Avatar
It appears the thermostat is a 2 pole thermostat which would be a little unusual since a 277 volt circuit has one hot wire and one neutral wire. Where did you get this heater? I suspect it was previously used in a residential setting and was wired to 240 volts, like you are going to do. Yes, it'll work, but at a reduced wattage.
