Lotus Mermaid 180 Fountain Pump
Received 0 Votes
Hello,
Joined this forum minutes ago.
Has anyone here owned a Lotus Mermaid 180, how does it work?
Here is a video:
Lotus Mermaid 180 Video by happytriger2000 | Photobucket
The door step of the entrance is flooded, need to empty the water asap:
but the pump seemed to be not working properly, when power applied to the motor pump it did turn but with some strange noise, sounded like the rotor is not tightly secured, the above video link was a test to see if it can suck water out, no water out at all....Does the pump has to be submersible in order to work?
thanks,
Here is a video:
thanks,
Welcome to the forums.
If the pump didn't perform in your test..... it certainly won't be pumping anything out.
It could be defective right out of the box.
That seems to be a small, very low flow and low lift type of pump not particularly designed for what you are doing.
