Central Vacuum Low Voltage Wiring Problem
Old 01-05-14, 12:18 PM
R
Question Central Vacuum Low Voltage Wiring Problem
Hi,
I purchased a central vacuum, but I need help with the low voltage wiring.
From the wall at the vacuum hole Name:  3.jpg
, two wires (which I cut) come out which contain 4 colored wires
How do I connect these two wires to the inlet valve that I bought?
I know you have to attache the wires to the screws of it at the top as seen in the picture but not sure which one goes where. Do I connect 1 wire containing 4 smaller colored wires into one scree and vice versa for the other one.
Thank you
Old 01-05-14, 12:31 PM
Received 1,167 Votes on 1,082 Posts
Welcome to the forums.
There are only two contacts on the wall plates and two terminals on the vacuum. There is no polarity. If you are using 4 conductor wire then double them up like red and green on one terminal and yellow and black on the other one.
Old 01-05-14, 01:17 PM
R
Hi. Thanks for the reply.
So to one screw, attach 2 red and green and other screw 2 yellow and black. Each screw contains 4 wires atached?
Old 01-05-14, 02:25 PM
P
Yes. Two red and two green on one screw and two black and two yellow on the other screw.
Old 01-10-14, 09:08 AM
R
Thank you everyone for helping me! I drew a diagram of the solution for future users who need help with this problem. Thanks again! Name:  Untitled.jpg
Old 01-10-14, 09:34 AM
A
Okay, but I think you have to make sure that the wires at the connection to the central vac unit itself has the red and green wires on one terminal and the yellow and black wires on the other.
Old 01-10-14, 11:44 AM
R
Of course...how the wires were connected via the outlets should be followed on the terminal. Thanks!
