Converting To Battery Operated
Old 01-05-14, 02:30 PM
R
Hi, I have a guitar amp that I want to convert to run on batteries so its portable but I don't know where to start.
I am hoping to do this the cheapest way possible, this is the information I have found on the back.
Voltage-230v
Frequency-50/60Hz
Fuse Type-5MM. 0.25 A Fast - BLO
Mains Power Consumption-12 Watts
Rated Output Power- 10 Watts-8 Ohm
This is all the information found on the back of the amp.
I have some 3.7v lithium ion rechargeable batteries kicking around that I could use.
Some options would be excellent, thanks in advance!!
Old 01-05-14, 02:44 PM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
Won't try and dissuade you...but the cheapest option would be to buy a new or used battery operated amp. You can probably find them all over the place at music and pawn shops.
Old 01-05-14, 02:56 PM
R
Yea I think your right, it would have been a nice project but awh well.
