Remedy for worst electrical box install ever - seriously
Old 01-05-14, 11:08 PM
Recently had some electrical work done. The guy had to cut in a new electrical box for a GFCI and cut the box at least a 1/4 - 1/2 inch off on the height. There is a visible gap and it is difficult to keep the box tight and in place.
Any suggestions to remedy this?
Old 01-06-14, 12:43 AM
Received 3,982 Upvotes on 3,574 Posts
A careful couple of shots of spray foam around the box.
Old 01-06-14, 04:12 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Is this in drywall? I am not sure spray foam is going to hold up from the force of inserting the plug after awhile.
Old 01-06-14, 05:46 AM
Received 1 Upvote on 1 Post
What did he use for a box?
Got a picture?
Old 01-06-14, 08:31 AM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
I've cut Madison straps down to make support pieces in cases like that. Those, plus careful filling behind them with joint compound, seem to hold up well.
A full patch of the drywall and cutting a new opening is the sure-fire fix.
Old 01-06-14, 08:57 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If he cut off the top of the box, it is a violation. That's why we asked for pix, just to make sure.
Old 01-06-14, 09:08 AM
pcboss's Avatar
I read it as the hole is too tall for the box, not that the box was actually cut. Pics would clear this up.
Old 01-06-14, 09:44 AM
chandler's Avatar
"Cut the box...off in height". Would be simpler, but that's what I read.
Old 01-06-14, 09:51 AM
pcboss's Avatar
I can see it that way too. .
Old 01-06-14, 06:57 PM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
Spray foam is surprisingly strong when allowed to stick to things, I have used on occasion with good results.
Old 01-06-14, 09:15 PM
I read it as the OP meant to write hole instead of box.
Old 01-06-14, 09:55 PM
Correct. I meant he cut the opening too tall and a little too wide. It is a blue new work electrical box that houses a single GFCI.
Old 01-07-14, 12:18 AM
pcboss's Avatar
They should have used an old work box.
Old 01-07-14, 08:23 AM
P
If you have enough play on the cable I'd say remove the box and install an old work box near it then patch the existing hole.
Old 01-07-14, 03:43 PM
Mr.Awesome's Avatar
You can just kill the power and mud, sand, touch up the paint?
Old 01-07-14, 10:44 PM
I will switch it out for an old work box, cut a new hole and patch the opening. I was looking for a solution to avoid this, mostly because I am really bad at patching holes.
Old 01-08-14, 02:08 AM
pcboss's Avatar
It sounds like you paid for this to be done. If so it should be on their dime to fix this and make it right, not you.
Old 02-23-14, 08:46 AM
While looking for light bulbs at the hardware store I stumbled upon a cover plate that is taller and wider, problem solved.
Thanks.
Old 02-23-14, 11:35 AM
chandler's Avatar
Not completely. Any gap between the drywall and receptacle cannot exceed 1/8", so you may still need to mud to close this up, if you haven't already done so.
Old 02-23-14, 10:03 PM
I will take a quick measurement and fill the gap if needed.
Thanks.
