Electric fireplace on a switch
Old 01-06-14, 03:27 PM
P
Is it ok to have an electrical fireplace on a dedicated 20 amp circuit controlled by a wall switch? The fireplace can't be turned on if the switch was accidentally flipped on because it requres a remoted control that turns it on and changes the settings from just a light to low power 600 watts to high power that is 1200 watts. I just thought putting it on a switch would be an extra safety step since a wall switch nest to the main light switches would have to be turned on to activate the receptacle and then the whole thing could be shut down when I leave the room. Any advice is appreciated.
Old 01-06-14, 04:48 PM
pcboss's Avatar
Received 210 Upvotes on 181 Posts
No code issues with your plan.
Old 01-06-14, 11:14 PM
P
Thanks for the reply. I appreciate your help.
