Running romex two directions
First outlet is under electrical box in basement. Running 12-2 wire I would like outlets to the right and to the left of the initial outlet in the circuit. What would my wiring look like at the first circuit?
To keep from crowding the first receptacle, I usually pigtail inside the panel. One cable to the below receptacle and left, while the other goes directly right. They will be pigtailed to the same breaker.
You may need a deep box at the first location.
You may need a deep box ...
Three xx-2 cables, one point per current carrying conductor: 6 points.
All ground wires (equipment grounding conductors: 1 point
All clamps or fingers inside the box to hold the cables: 1 point
Each device (single or duplex receptacle or switch, etc.): 2 points.
Pigtails: 0 points.
Wire nuts: 0 points.
Total: 10 points
For 12 gauge wires use 2-1/4 cubic inches per point, or 22-1/2 c.i. or larger box needed.
