Electrical Conduit Questions
Old 01-14-14, 05:24 PM
D
Can I run electrical conduit from the basement to the attic through the access panel near a shower?
Old 01-14-14, 05:27 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! More info is good. What is the conduit for? Is it EMT, PVC? How "near" the shower.
Old 01-14-14, 05:58 PM
D
Well I was planning on a couple things.
The first conduit I was planning on PVC to run an ethernet cable and a rg-6 coax cable to the attic bedroom.
Future plan: The second conduit was going to be EMT to run new electric upstairs to the first outlet in the series of outlets to provide a safe ground from TV/satellite box.
The only interior wall I can find that will require no holes in the wall (only opening the access panel to the plumbing to the shower. I assume I can run them ~6 inches away from the actual plumbling. And the shower/bathroom was recently redone with waterproof rock.
Old 01-14-14, 06:08 PM
Tolyn Ironhand's Avatar
Received 882 Upvotes on 745 Posts
Eithernet and coax are low voltage cables and pose no danger. You can run them without conduit if you want.
Old 01-15-14, 06:39 PM
D
I plan on doing the conduit as it is only 1 floor and I dont want to keep accessi ng the wall if i need to run future ethernet or hdmi or whatever...
And if I want to run electrical as well to provide a grounded outlet upstairs, I would run a separate EMT conduit.
Old 01-16-14, 05:52 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I wouldn't waste my time with conduit in a residential application unless this was outside, which it isn't. Just pull two 12-3 NM-B cables up there and be done with it. That'll provide you with up to 4 new 20 amp circuits if and when you need them.
Old 01-16-14, 06:29 PM
Adding a pull string with any cables you pull in will allow you to pull more in later. every time you pull a cable just add a string.
