Apartment Thermostat issues! PLEASE HELP!
Old 01-16-14, 08:32 PM
sinfemmy's Avatar
I need help with a White-Rodgers 700 Electronic Non-programmable Single Stage Thermostat
Issue: It only blows out hot air. Seems to blow air even when I switch it to off. Today it was nearly 76 degrees outside, but 85 degrees in my house!!!
I am looking at a manuel right now, but I don't understand.
Manuel
Any help would be greatly appreciately.
Old 01-16-14, 09:13 PM
F
Is this an apartment that you own or are you the tenant? If you do not own the apartment you need to have the landlord or his/her authorized person do the work. If YOU cause any damage then you are totally responsible for all costs to repair and maybe more.
Received 3,880 Upvotes on 3,477 Posts
Welcome to the forums.
It's very rare for the thermostat to keep the heat running when it's switched to OFF mode.
Do you have an electric furnace ? (not gas and not a heat pump)
If your furnace is electric the problem sounds like a sequencer relay is stuck on.
Old 01-17-14, 01:35 AM
B
As mentioned if this is a rental, I would first turn off the breaker to the furnace. Then call the landlord or HVAC contractor, which ever applies.
