Fluorescents and grounding
Received 0 Votes
Was doing some cleaning and noticed the green grounding screw inside my metal fluorescent fixture is not used.
We have conduit. The fixture is connected to the conduit with a connector and a knockout. I assume we are mechanically grounded as I have read about here.
There is no grounding wire coming from the ballast.
So is this a bad thing? Will my light not function properly if that green screw isn't used?
Received 0 Votes
It is screwed to the housing.
I found the installation instructions and it says to make sure its grounded otherwise it can cause a shock hazard, overheating, premature bulb failure or a non functioning light....
I understand shock hazard but what about the rest? Please explain....
Received 0 Votes
Fluorescent Lamps
Your conduit is the ground for your fixture. If the fixture was not grounded it most likely would not light properly as a grounded surface is needed along the length of the lamp. Hear is a good explanation of the need for the grounded reflector:
"Newer rapid start ballast designs provide filament power windings within the ballast; these rapidly and continuously warm the filaments/cathodes using low-voltage AC. No inductive voltage spike is produced for starting, so the lamps must be mounted near a grounded (earthed) reflector to allow the glow discharge to propagate through the tube and initiate the arc discharge. In some lamps a grounded "starting aid" strip is attached to the outside of the lamp glass."
