Transformer
Old 01-19-14, 01:44 AM
T
Transformer
Hello
I have some nichrome wire that I want to use.
I need 3V and 4A to get it to the right temperature.
What's the easiest and cheapest way to get these requirements?
It seems difficult to find a transformer with an output from 3V and 4A.
I live In Belgium so we have 230V
I would use the wire for sealing plastic bags.
I was thinking of using teflon tpfe to prevent the bag from sticking to the wire.
I read some different melting point of teflon. Some say 260C, other say 330C.
If I use 4Amps then the wire would heat up to 230C.
If I use 5Amps the wire would heat up to 310C.
On the other hand, It is just for a brief moment that the wire needs to be heated.
I don't know which temperature would be the best for sealing the bag.
I will use a constant heat sealing, not an impulse heat sealing
Thank you!
Old 01-19-14, 05:06 AM
P
Received 2,217 Upvotes on 1,979 Posts
I have a variable transformer on my hot wire cutter. With it I vary the voltage instead of trying to limit the current.
