One pump,two feeds
One pump,two feeds
Hi guys, I need an expert opinion on this schematic. ...http://i224.photobucket.com/albums/d...ps7d50c094.jpg
Will feeding the pump from two relays at the same time blow a fuse or worse?
No....it would not be a problem if both relays are activated at the same time.
Since you've used a common supply circuit it is ok to have both relay outputs combined.
