Duplex 3 Way Switch Question
Old 01-20-14, 08:35 AM
Im thinking of installing a double three way switch (toggle top and bottom duplex). Home centers don't have them though.
This will control two lights from one single gang location, both lights are on different circuits.
Is this allowed?
Is there a tab on the device that one would remove like a split receptacle in this case?
Old 01-20-14, 09:46 AM
ray2047's Avatar
Yes, it is allowed. If there is a tab it will be removable. All grounds must be tied together even if separate circuit breakers. Neutrals must be kept separate if separate breakers. A lot of wire for a single gang box. Use a deep box.
Old 01-20-14, 10:11 AM
Why is there a tab to be broken on these devices?
And do you know where I can buy this device?
The big box stores do not carry 3Wx2 just 3w and 1 pole. Would prefer toggle to decora.
Old 01-20-14, 10:32 AM
pcboss's Avatar
Received 195 Upvotes on 171 Posts
Is this what you are looking for?
Combination Switches, 693LAG | by Legrand
Old 01-20-14, 10:48 AM
exactly, just without the ground pigtail. Probably will have to go to a supply house unless I can find an online retailer.
Old 01-20-14, 11:40 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Old 01-20-14, 11:45 AM
ray2047's Avatar
If there is it would be on the common so one hot wire could supply both switches. On the other switch the tab would be removed to provide separate power to each light. That said never installed that type of switch and can't say if they have a tab.
Old 01-20-14, 12:10 PM
chandler's Avatar
My mistake on the reference. That is a three way/spst combination. They carry them. I just couldn't find it on line. Jim's reference is a true double three way.
Old 01-20-14, 12:50 PM
Nashkat1's Avatar
Received 6 Upvotes on 5 Posts
Leviton 5243
Leviton 5243-I at Amazon
Leviton 5243 at Sears
Old 01-20-14, 01:06 PM
pcboss's Avatar
The ground pigtail should be no issue. If your wiring does not have a ground it will just get tucked in the box unused.
