Portable ceramic heaters
Old 01-23-14, 07:01 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi All, why would a ceramic heater be more efficient than a conventional heater of the same wattage? Watts are Watts
Geo
Old 01-23-14, 07:40 AM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
They are not more efficient, watts are watts.
Old 01-23-14, 10:49 AM
Geochurchi's Avatar
The thing that I was wondering about is wether there maybe more residual heat from the ceramic disc's.
Old 01-23-14, 10:52 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Maybe....but that just means the fan runs longer to remove it, depending on setting. Watts is watts
Old 01-23-14, 12:00 PM
ray2047's Avatar
Simple science. You can't get eight gallons of water from a five gallon bucket. And since most electric heaters are better then 95% eficient there isn't must lost energy to somehow recoup with better design.
Old 01-23-14, 07:52 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Old 01-24-14, 04:25 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
No argument that watts are watts, but I have a small box ceramic heater in my office and once it gets cranked, I find myself turning it down, but don't notice a marked decrease in heat. I believe once the ceramic disks get heated, it takes less wattage to maintain that heat. It will kick on every 10 minutes or so to a higher speed, but settles down after a bit. They are safer, too. Although there is a bunch of heat coming out, you can lay a piece of toilet paper over the face and it will not catch fire.
Old 01-24-14, 04:54 AM
W
Received 63 Upvotes on 55 Posts
Heater
Just what I need in my bathroom on these cold mornings.........
Old 01-24-14, 07:58 AM
My favorite heater is my 660W parabolic heater. While it's not a lot of power, it makes me feel warm, which is the important thing.
Old 01-24-14, 09:26 AM
CasualJoe's Avatar
That sounds a lot like advertising for oil filled electric heaters. How many watts are consumed heating the ceramic disks? I agree that whether you have ceramic disks or an oil filled heater, the output of heat would be more even, but still, a watt will only produce X amount of heat.
Old 01-24-14, 01:46 PM
chandler's Avatar
Oh, I agree CJ, but I just feel the initial wattage to bring the ceramic up to par falls off saving a little, and sort of going on "idle" so to speak.
