USB plug and 3 pin plug help needed to connect the wires
Old 01-24-14, 05:25 AM
So im working on a project, to make an iphone 5 charger without the usb plug.
I dismantled the usb plug and found out that there's 4 different wires namely, d+, d-, v and GND
I also dismantled the 3pin plug for iphone charger and found out there's 2 wires namely the live and neutral wire
So i have a question how do i connect the wires to make the charger work without using the usb port?
Thanks in advance!
Old 01-24-14, 05:52 AM
T
What "3 pin plug"? Lightning is an 8 pin connector.
Old 01-24-14, 09:37 AM
you know the 3 pin apple plug? the one which connects the lightning cable.
what i meant was is there anyway i can remove the usb port and directly connect the live and neutral wire to my lightning cable to make it work without needing to plug it in
Old 01-24-14, 09:47 AM
ray2047's Avatar
Post withdrawn.
Old 01-24-14, 10:02 AM
T
No I don't know what a 3 pin apple plug is. I have never seen a 3 pin plug on an apple product. Lightning is 8 pins, and it has a USB on the other side which is 4 pins.
I just noticed you are outside the US.. Do you mean a 3 pin mains plug??
If that's what you mean, then no. You can not remove the piece that turns the 240v from the wall outlet into the 5v that your iphone needs.
Old 01-24-14, 10:43 AM
oh so you're unable to do it?
actually i doing a project which is an iphone casing charger where there will be 3 pin main plug behind the casing which there will be live and neutral wires.
so i was wondering how am i suppose to connect the wires from the lightning cable to the live and neutral wire. so i guess i cant
is there a solution or do i have to stick to the usb pins?
Old 01-24-14, 11:54 AM
T
No. You can not connect your iphone directly to 240v. If you could, they would just do it that way to begin with. The little box between the mains plug and the USB port is not a decoration.
Anything you do will have to step the voltage down from 240v to 5v, and convert it from AC to DC.
Don't take offense to this, but considering that I had to explain this simple concept to you, I don't feel you have the prerequisite knowledge to do what you want to do without creating an extremely dangerous situation. Therefore I will not offer any guidance on how to do it.
