Hooking up a dishwasher without a ground
Old 01-25-14, 10:11 AM
I got a new Bosch dishwasher. The old GE dishwasher had the whip with 2 wires go into a box connected to the dishwasher and it was grounded to the box on the dw.
The new dw has a cable that plugs into the back of the dw and a plastic electrical box. Obviously I can't ground to that and it says it the dw must be grounded.
Running a ground wire to the panel is not feasible (ripping walls, floors apart would be involved).
The whip to this plastic box is coming from a metal electrical box under the sink. Can I ground to that? The whip is armored cable and metal, so I'm not sure if that affects grounding.
Old 01-25-14, 10:27 AM
pcboss's Avatar
If the metal box on the wall is not grounded there is nothing to ground to. What wiring method do you have?
Old 01-25-14, 10:29 AM
The box under the sink is fed by greeenfield. The whip going to the dw box will be greenfield as well.
The greenfield doesn't go all the way to the panel though. I see solid conduit come out of the panel.
Old 01-25-14, 10:33 AM
pcboss's Avatar
A metal conduit can serve as a ground. Since you have conduit you could pull a grounding conductor in.
Old 01-25-14, 10:36 AM
It is 3/8 armored cable with 2 12 awg wires in it. I have no idea where it snakes and turns. Unlikely anything can be pulled through it.
Old 01-25-14, 10:40 AM
I think it is going to come down to it not being grounded or spending a lot of $$$$ to get it grounded. If it isn't grounded, what can happen and how likely is it that that will happen?
I'll add the last dishwasher was there for 15 years without issue.
Would putting a GFCI on the circuit help?
Old 01-25-14, 10:59 AM
pcboss's Avatar
That is not Greenfield, it sounds like AC cable. If it has a bond strip it is already grounded if properly installed.
Old 01-26-14, 07:57 AM
Do you a meter? (analog is best ) Check between the hot black wire and the metal casing on the armored cable and see if you have 120 volts is so it is grounded.DW should be grounded!
Geo
Old 01-26-14, 10:10 AM
pcboss's Avatar
That is not the way to see if the cable is actually a grounding means. Even the AC without the bond strip will still show as grounded.
Old 01-26-14, 04:03 PM
I don't believe I have ever seen AC without a bond strip,but maybe it's me.
Old 01-26-14, 05:56 PM
pcboss's Avatar
Older AC did not have the bond strip.
Old 01-26-14, 09:10 PM
CasualJoe's Avatar
MC cable has no bonding strip and it looks like AC cable, but most MC cable has an insulated green ground wire.
