Need outlet, no place to mount box
Received 0 Votes
I would like to place an outlet next to my water heater for a possible upgrade to a fan assisted gas wh at some point. In the meantime it would serve as a utility outlet/junction in the basement.
There is no wall surrounding the water heater to mount a box. A joist above is the closest member to attach too.
What options do I have besides building a wall!!?!
I would like to place an outlet next to my water heater... There is no wall surrounding the water heater to mount a box. A joist above is the closest member to attach to... What options do I have besides building a wall!!?!
A cripple being a short piece of lumber, in this case long enough to extend straight down from the joist to a convenient working height, and a brace being a kicker, or second piece of lumber, at something like a 30-45 degree angle to a second joist, as a matter of stabilizing the cripple. Or you construct something out of unistrut, although that would probably be overkill (a term used to describe going above and beyond practical).
Received 0 Votes
Thanks. I understand what your describing I am just having a hard time visualizing what hanging a cripple would look like. The hanging box likeRay mentioned came to mind but I would prefer it to be attached.
Fan assisted and condensing water heaters use a cord and plug correct? Or are they hardwired?
You also need to determine whether the one you get requires an in-reach disconnect.
Received 0 Votes
md2lgyk
I'd mount a surface outlet on an outside wall.
As stated in the original post, there is no wall surrounding the intended place within a reasonable distance. Its in the middle of an unfinished basement.
I will be exploring the options that were already suggested for this intended installation.
You could come down 18" if you use two threaded conduits to support the box.
Otherwise get an 8' length of Kindorf or similar. Secure at top and bottom then you can attach EMT and a box to it.
Mount a 4x4 by the water heater. You can then also use it to hang up any inspection papers or junk like that for the water heater.
Strut is a good idea but I think it would look funny in a home.
Strut is good, but it is expensive. Sometimes also called, Kindorf.
