Which brand/model 200 amp combo panel in CA for residential?
I'm looking to upgrade my old 100amp service to 200amp. I've been told Square D QO is a good panel. At Home Depot I think I've only seen the Homeline series. Are those ok? I hear the Cutler-Hammer is also a good panel. I'm looking for a semi-flush (or capable) 20/40, preferrably with the meter socket at the top/center. I just read in CA it also has to be EUSERC certified. Do you guys have a specific brand/model you would recommend? Thanks in advance!!
Square D QO series is a good quality piece of equipment and comes standard with copper bussing. QO series breakers are liftime warranted. Square D Homeline is alright, but is only available with aluminum bussing and uses a slightly different circuit breaker. I think I'd check with the utility company to get a list of exactly what manufacturers and catalog numbers they approve. Not all EUSERC member utilities accept all EUSERC certified equipment.
Frequently Asked Questions
Thanks Joe!! Are the GE panels any good? Also, I have to have acfi's and there is some knob and tube in the house. Do I need a MOD3 breaker for this or anything special (besides getting rid of the k&t? lol).
GE panels are OK, but I don't like them or GE in general. I'd rather use Siemens or Cutler-Hammer. Cutler-Hammer makes equivalents to Square D, the CH series with standard copper bus and lifetime warranted breakers as equivalent to Square D QO series and C-H BR series as equivalent to the Square D Homeline. That being said, I believe the C-H BR series is superior to Homeline because many of the BR panels are available with copper bussing where Homeline is aluminum bussing only. I do not like the way Square D conducts their business since being purchased by Schneider Electric, a French company, and cannot justify the heavy premium price they demand.
Does the AHJ require AFCI breakers on a service upgrade? If not, I wouldn't use them since you still have K&T wiring.
Yes, the inspector has told me before that acfi's are required. Then I read something about using a MOD3 breaker when you have K&T. Or is the inspector going to make me replace the K&T?
