install garbage disposal to an on/off switch
Old 01-30-14, 07:59 PM
A
Need help hooking up mu garbage disposeal to an on off switch. Wires coming in are white black and a bare wire. And the same wires are on the disposal.
Old 01-30-14, 08:17 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
Not sure if you are in the US or not, but here garbage disposals now need to have a wall plug, and an outlet. You would then put the outlet on a switch.
Mod Note: The NEC allows a GD to be hardwired also.
Old 01-31-14, 04:53 AM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
Are the wires coming from the electric panel or from the switch? Are the wires to the switch already installed?
Old 01-31-14, 08:17 AM
Received 1 Upvote on 1 Post
One easy way is with an air switch.
Here's the directions to install for one brand but there's lots of other brands that cost less.
InSinkErator | SinkTop Switch Installation Instructions
