Clearence for box and fixture
Received 0 Votes
I would like to mount a box and a porceline pull chain lamp holder at the bottom of my basement stairs on a wall. The box would sit flush on wood panelling and drywall on the ceiling and another portion of paneling would be within 6" of the bulb.
What is an acceptable clearance for a such a fixture?
Are you mounting it on the ceiling or the wall? Your first sentence says a wall, but the second says the ceiling. Also, will it be on wood paneling or drywall: it can't be both, unless there is drywall behind the paneling. A picture of where you want to put it would help.
Received 0 Votes
No photo right now.
It will be flush on the wall (paneling). Picture the bottom step and then to the top of the wall on your left. The slopped ceiling of the stairwell is there as well as the header (also paneled) in the entryway into the basement.
So the ceiling would be within inches of the bulb and the header would also be in proximity.
I don't think it will be a problem, considering that I've seen lots of bathroom light fixtures where the bulb fixture is 6" or so from the wall. I'm thinking you will be using an incandescent bulb, probably 100w, bare (no cover). Have you looked at other inexpensive alternatives? Here are a couple:
- Amerelle 4 in. Round Utility White Light with Pull Cord-73012 at The Home Depot
- Design House 1-Light Satin Nickel with Opal Glass and Pull Chain Ceiling Light-519272 at The Home Depot
Received 0 Votes
Ide say about 6 inches Joe. I was thinking of using your standard Leviton pull chain holder with a 75W or a 100W equivilant CFL.
FWIW: I bought a rough service 100W bulb from Sylvania a few weeks ago for a work light.... so can still get them but not like your standard fixture bulbs.
