bonding together PVC electrical conduit?
Old 01-31-14, 09:22 AM
R
How do I bond together PVC electrical conduit? Is it the same primer and adhesive used in plumbing or something else? Thanks Roger
Old 01-31-14, 09:23 AM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Yes....though I'm not sure primer is needed for conduit?
Old 01-31-14, 09:26 AM
Received 1 Upvote on 1 Post
Just use PVC glue, no primer needed.
Old 01-31-14, 09:33 AM
ray2047's Avatar
No primer. The cement is gray for PVC conduit not plumbing cement.
Old 01-31-14, 11:22 AM
R
Thanks for the quick replies, everyone. I appreciate it. Roger
Old 01-31-14, 12:12 PM
Received 800 Upvotes on 703 Posts
but you can use regular plumbing cement, right? I didn't know there was a different PVC cement and have used plumbing cement in the past - never had any failures that I know about.
Old 01-31-14, 12:37 PM
Nashkat1's Avatar
Received 5 Upvotes on 4 Posts
We use the purple stuff for our plastic pipe runs. No worries with it, even after years.
Old 01-31-14, 01:18 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
I would basically agree with Ray, but don't see the harm in using a plumbing PVC cement. Actually, I have never seen primer used on PVC conduits, but Carlon does makes and recommend primer as well as a whole line of PVC cements.
http://www.carlonsales.com/Cement%20...alers_2F18.pdf
Old 01-31-14, 04:31 PM
Mr.Awesome's Avatar
I'd like to blow your minds and let you know I've used YELLOW stuff!
