3 way switch help
Old 02-02-14, 11:15 AM
O
3 way switch help
Hello,
I have the following that is existing and functions without issue. I have switch one with power coming and 2 lights coming off of it. There is a 12/3 that runs to the second switch.
what I am wanting to do is add an additional light but add it to switch 2. How would i go about wiring this up?
THanks for the help.
Old 02-02-14, 11:45 AM
Received 3,884 Upvotes on 3,481 Posts
All lights need to be added to the three way circuit in the same location.
You can not connect lights at the second switch as there will be no neutral there.
Old 02-02-14, 11:54 AM
W
Received 63 Upvotes on 55 Posts
Second Light
Connect the second light to the first light rather than to a switch.
Old 02-03-14, 07:02 AM
olson2334,
Did the Honeywell TH115-A-120S Thermostat work on your
Panasonic FV-11VH2 bathroom heater???
If not, did you find something else that worked?
Thanks
