Portable Generator Wiring help
Old 02-03-14, 05:39 AM
E
i just wanted to know if this is the correct way to wire, power source is from a generator.
Name:  Portable Generator Wiring.jpg
Old 02-03-14, 07:55 AM
ray2047's Avatar
Is this to be a separately derived system not a part of another system with a power source?
Old 02-03-14, 08:19 AM
E
yup, the power source will only be the generator only.
Old 02-03-14, 09:40 AM
ray2047's Avatar
That should work then.
Old 02-03-14, 10:41 AM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
You need a circuit breaker between the 30A inlet and the receptacle, which can be on no larger than a 20A circuit.
Old 02-04-14, 06:55 AM
F
Breaker?
Wouldn't a breaker be unnecessary if there was a 20 amp breaker on the generator?
Old 02-04-14, 07:39 AM
ray2047's Avatar
That is correct.
