Pool Pump Switch
Old 02-04-14, 07:20 PM
Pool Pump Switch
My issue is a distant cousin similar to the above issue with wiring. A while back I had to remove my pump and have it rebuilt. I failed to take a picture of how the pump and timer were connected via a previously installed 'isolation' switch and also a power company installed on-call device (with a black, red, and blue wires as indicated in diagram) if you will. I will explain just in case anyone doesn't understand the context here. The switch allows me to turn off or isolate the pump motor from running without having to cut the breaker and resetting the timer whenever I do maintenance around the pool. Below is a schematic of the wiring as it is in my situation- I simply need help connecting the wires back to the switch. TYIA!
[img=https://www.facebook.com/photo.php?fbid=581068961983813&set=a.168653549892025.40207.100002421423398&type=1&relevant_count=1]
Old 02-04-14, 07:57 PM
Tolyn Ironhand's Avatar
Received 814 Upvotes on 685 Posts
Welcome to the forums!
It is almost best to start your own thread so that it gets the attention it deserves.
I don't believe you can link to facebook on this site. Either upload your picture here if it is small enough, or use a hosting site like photobucket.
Old 02-04-14, 09:20 PM
ray2047's Avatar
