Electrical outlet slow to charge phone
Old 02-05-14, 01:27 PM
L
Hi, I've got an electrical outlet in my kitchen that I've noticed is VERY slow to charge my phone. Other appliances such as blenders work fine when I use that outlet though. I'm just curious what the cause may be and if it's acceptable per code (I live in TX). It's a new house and the warranty expires soon so I want to make sure any issues are taken care of before that happens. Thanks!
Old 02-05-14, 01:38 PM
Received 1,421 Votes on 1,314 Posts
If that receptacle is delivering enough power to run an appliance like a blender..... then it's doubtful that it could be affecting a charger.
The only way to know for sure is to check the voltage at that receptacle with an AC voltmeter.
Old 02-05-14, 01:54 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Does it charge faster in a living room or bedroom receptacle? How are you judging how fast it should charge?
Old 02-05-14, 02:00 PM
L
Yes, it charges faster in the bedroom, office, etc and when plugged into other outlets in the kitchen.
Old 02-05-14, 02:09 PM
Received 35 Votes on 33 Posts
Are you using a wall charger or does the outlet have a built in USB socket?
Old 02-05-14, 03:43 PM
L
I'm using a standard 2 prong wall charger.
Old 02-06-14, 06:32 AM
The wall charger either is defective or has a lower output current then the other ones that you are using.
If you are charging an iPhone I believe you need a charger that can output 5VDC @ 2.1A
The lower the output current the longer it will take to charge also if the output current is too low the phone may not even charge
Old 02-06-14, 02:46 PM
sounds like the OP is using the same charger in different outlets.
if you've got a warranty, then perhaps just tell them you suspect the outlet is faulty based on what you've tried thus far. not sure if it will solve the problem though.
Old 02-06-14, 04:16 PM
Mr.Awesome's Avatar
Check you connections on the receptacle, especially the neutral.
