Doorbell repalcement
Received 0 Votes
I need to replace an old nutone door bell. I have a 20v suplly coming to the old doorbell. Can I use this 20v supply on a new 16 or24v doorbell or do they still make a 20v doorbell? I am trying to avoid replacing the old transformer.
This is my first visit. did your recieve my question?
Doorbells are usually 7-10 volts. Was this a chime you are replacing? If you are replacing it with a chime 20 volts should be okay. The transformers are so cheaply made 20 volts is well within the expected error range for 17 volts.
Received 0 Votes
Door bell voltage
Thanks for response. the old doorbell was a 20yr old elctronic programmable one. I want to use what ever Lowes may have in a cheaper model. They all seem to be 16v. My supply from the transformer is 20v. I think they also have 24v models. All I am trying to do is not crawl under the house and replace the transformer if I don't have to.
Received 0 Votes
No, it didn't have batteries. I called nutone and asked the same question i asked you and he "OF COURSE SAID" i needed to buy a transformer with the new unit i purchase. My thought was "hey volage is voltage" why should I have to do that. Me thinks he was trying to sell a product--Ya think. thanks for the info.
If the transformer isn't obviously connected (setting next to it) you need to check the voltage output of the transformer at the chime to see if it is 17 volts AC (±20%) or if it is 12 volts DC just in case you are looking at an old transformer no longer connected.
Received 0 Votes
door bell
The measured voltage is 20v a/c. this supply line goes down in the wall and I suspect that the transformer is mounted on a floor joice in the crawl space under the house.
I hope your didn't confuse the word transistor thinking I meant transformer.
Received 0 Votes
The model I'm replacing is an 1982 vintage. You are thinking the same as me. I feel like perhaps the model that was originally installed was a standard and the previious owner of this house(who from what renovations he had done gave away his ineptness to even think about being a handyman) installed this unit and that is probably why the unit failed, knowing his knowledge of electricity. He probably just hooked it up not thinking of the voltage requirements.
