Adding electric to shed questions
Old 02-07-14, 10:55 AM
F
I have a wood framed shed on wooden skids that is 10X16. I am converting it into a bunk house insulated, with a window air unit, light and a couple of receptacles. The shed is about 20 feet away from my power pole and 200amp exterior breaker box. I have never done electrical on my own but helped the guy that installed electrical in my shop. I have installed switches, receptacles etc. I have three roles of wire, white, green & black, pvc conduit, boxes etc left over from that job.
So I was thinking of adding 2 20 amp breakers and running three wire from each breaker, through pvc conduit underground to the shed one breaker just for the AC. The other for a receptacle and a light with switch.
First, is there any issue with this setup?
How would I wire a switch for a light Is the building grounded enough to attach the ground to the box and how does that work if Iím using pvc boxes?
Any input is welcome
Old 02-07-14, 11:28 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
First you can only have one circuit feed the shed. A multi-wire branch circuit could be used in your case. You can search sub panel on this site as it is a frequent topic.
Old 02-07-14, 01:32 PM
F
Is there a reason I cannot run two circuits? That is how we did the shop?
No code out here in the country.
Old 02-07-14, 01:47 PM
pcboss's Avatar
The NEC prohibits more than one circuit or feeder to a building unless the voltages are different like a 120/240 and a 277/480. The answers here will be code compliant regardless of lack of local enforcement.
Old 02-07-14, 02:28 PM
F
There won't be much use in this building the small A/C 110/5amp a couple of lights. Can one circuit handle that and if so I would be happy doing one.
Old 02-07-14, 05:38 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The multiwire branch circuit PCboss suggested will provide you with two 20 amp 120 volt circuits. It's a 4-wire circuit; two hots, one shared neutral and one ground. You'll need a disconnect at the shed, a 2 pole 20 amp switch in a weatherproof box with a weatherproof cover will work and is not expensive. The multiwire branch circuit needs to originate from either a 20 amp 2 pole breaker or two 20 amp single pole breakers with a handle tie.
Old 02-08-14, 04:59 AM
F
Okay,
So 2 hot wires, ground and neutral to a sub panel. Thats going to require two ground rods, correct?
I think I'll do the digging and set up and I'll hire someone to do the connect.
Old 02-08-14, 06:35 AM
ray2047's Avatar
Okay,
No, no subpanel is used. You do need a two pole disconnect switch but that is all.
Old 02-08-14, 08:15 AM
Out of curiosity, what exactly is unsafe about running two, 20-amp circuits to this shed? Yes, I know it's a NEC violation, but this is not a "local enforcement" issue. There are, believe it or not, places in the U.S. with absolutely no building codes.
Old 02-08-14, 08:28 AM
pcboss's Avatar
I don't know the reason but expect it has something to do with only shutting off part of the pwer and someone thinking it is all dead.
Old 02-08-14, 08:50 AM
F
Ohhhhhh, okay.
That is totally do able. Then I would not need ground rods etc. Correct?
Old 02-08-14, 08:56 AM
pcboss's Avatar
The multi-wire branch circuit counts as one circuit and does not require ground rods.
Old 02-08-14, 11:09 AM
F
PCBOSS & Ray207
This is making sense now. Thanks for the information.
Old 02-08-14, 12:26 PM
ray2047's Avatar
And when you get the shed wired you can fix the shop wiring.
