240 Socket Type
Old 02-10-14, 02:02 AM
D
240 Socket Type
I want to add a 20 amp 240v outlet in my garage. What is the appropriate outlet type? Should it be a 3 wire or 4 wire?
Old 02-10-14, 04:28 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
What will be running on this receptacle? Generally a 3 wire NEMA 6-20R is needed.
Old 02-10-14, 07:13 AM
ray2047's Avatar
Above is advice for an attached garage only. You can not add 240 to a detached garage that already has 120. The 120 must be abandoned and a subpanel installed.
Old 02-10-14, 07:24 AM
D
yep. an attached garage. That will match well with the compressor that I have.
What would be appropriate for a 30amp circuit. Might consider an heater after the cold winter we had.
