Where to find the most appropriate 3v or v6 motor
Hello,
I'm looking for a motor that is 3v or 6v powered. The motor should turn as slow as a clock. And be flat in order to close the cover. Any idea?
Thanks
Thanks
Small Motor
Here is a place to start. You could also try contacting some of the motor manufactures of hobby motors. Size will not be the only consideration as how much torque you need will be a consideration.
Hobby Engineering: Motors Section
