Best way to extend outlet in garage
I have a 20amp outlet on one side of garage but need it on the other side. Don't want t tear up the wall so thinking surface wiring, what is the best way (functional and best looking) to accomplish?
Ray's idea is best, but it may be a pain to drill into the top plates of your walls if you roof is at a sharp angle.
You could also mount a handy box extension on you current box
http://www.garvinindustries.com/imag.../G19280-EA.jpg
Then use emt to pipe over to where you want the new plug.
Again, Ray has a valid suggestion.
Mine is based on personal taste. In my own garage I would rather see emt over wiremold. Wiremold seems more household/office to me.
So why can't you run it through the attic?
I did not know if I can get to the top plate of the outer wall from the attic since it is the edge of the roof where it tapers down.
A better pro then me would use a flexible drill bit from the receptacle box but they need practice also. Klein Tools Flexible Drill Bit Kit (3-Piece)-53721 at The Home Depot
But then there are the extra problems caused by insulation.
So in summation I ask and your original reasoning was valid not mine.
