Add Outlet to Bathroom
Received 0 Votes
I'm putting a GFCI plug in my bathroom (which currently has no outlets). There is only one set of wires connected to the switch (the white and black are both connected to the switch in its current setup). When looking at the light, the blacks front the light are connected and the whites for the light are connected to the red. I'm a little puzzled. Thought the white is a neutral and not to connect to the light switch itself? Any thoughts on how I can integrate an outlet in this?
Thanks!
Thanks!
Sorry for the delay, the red wire is connected to the light fixture itself (to the white wires coming from the fixture)
Explanation: From what you wrote it sounds like they used a 3-conductor cable (white, black, red) for the switch loop and connected it wrong. If so this may be easier.
