Electrical panel maxed out?
Old 02-16-14, 09:32 AM
B
Hello,
I have a 100 amp electrical panel and I am wondering if it is maxed out an if I wished to add anything it would need an upgrade?
I have attached two pictures of the panel. The main reason I ask is that I have a 30A breaker right in the middle that seems to have nothing attached to it. I am guessing there is probably a valid reason for that, but thought it didn't hurt to ask before I call a local electrician over to my house.
Old 02-16-14, 11:14 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
That is indeed and old panel and a bit strange looking. That wouldn't be a really old Zinsco panel, would it? Is there a label anywhere or a name embossed into the panel door?
Old 02-16-14, 11:27 AM
B
On the cover it says...
XO (R) Circuit Breaker Load Center
SQUARE D COMPANY
The house was built in 1954
Old 02-16-14, 11:35 AM
CasualJoe's Avatar
SQUARE D COMPANY
Ok, that would be fine except that you'll have an extremely hard time finding a breaker for it. Some used XO circuit breakers are available, but your selection is limited and you'll have to do an internet search to find them. In theory you could use the 30 amp breaker not being used or even install a subpanel, but I'd recommend you upgrade the old panel. If you don't forsee needing a lot more power in the future, you could put in a new modern 100 amp 30 circuit copper bus panel.
Old 02-16-14, 11:47 AM
B
Thank you very much. I appreciate the info and advice.
Old 02-16-14, 12:02 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Having a maxed out panel is different than just needing space for more breakers. A demand load calculation would tell you if the panel can supply enough power.
Old 02-17-14, 10:24 AM
B
Thank you. I will give that a try. I have a formula (derating service capacity) in a basic wiring book I picked up on a whim long ago.
Old 02-17-14, 12:43 PM
A
Received 83 Upvotes on 75 Posts
If you would like to go the spreadsheet route this one does just about everything for figuring out a load for a house - https://www.mikeholt.com/documents/c...lculations.xls
