Basement bedroom wiring
Old 02-16-14, 10:39 PM
markzrt1's Avatar
Hello,
Just got done framing a 12'x13' bedroom in our basement and I'm ready to start the electrical. I will need 1 switch for a light and 5 outlets. There is a line dedicated for this bedroom tucked away in the ceiling. I assume I will need a junction box to start and where do I go from there?
Thank you.
Old 02-17-14, 02:29 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Rather than attempting to give you Electrical 101 in a nutshell, it would be a good investment to purchase the book called Wiring Simplified. It is a treasure trove of information on how to wire things, what to expect, what to do and what not to do according to code. It is available at most box stores, and surely at libraries and book sellers.
Old 02-17-14, 05:12 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
The basement bedroom may also require an egress window. Talk to your building officials.
Old 02-17-14, 08:46 AM
Mr.Awesome's Avatar
Personally I would use that cable for the receptacles, and run either a new circuit for the lights or bring power in from another lighting circuit. And also since it is a basement, get a rough idea of where the bed and furniture is going and install a dedicated receptacle for a space heater. (I am unsure of what your winters are like when I say this by the way)
But if you intend to do it all on a single circuit...
The Jbox will work if you have tiled ceiling. Boxes must be accessible so you cannot board over them.
I would bring the cable in to the switch box, use a 4x4 deep box with a 1/2'' mud ring. Bring a 14/2 to the light, and a 14/2 to the first rec. and then off to the other 4.
And have you considered a data and phone jack?
Old 02-17-14, 08:56 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
I like this idea becasue the OP is in Minnesota, cold winters up there. The wire size for the existing circuit should be based on whether the existing circuit is a 20 amp or 15 amp circuit.
Old 02-17-14, 09:58 AM
B
New Bedroom
I would use a single circuit for the bedroom unless you can extend a circuit from another bedroom that already has the required Arch-Fault protection. You will also need the required smoke detectors.
Old 02-17-14, 10:53 AM
Mr.Awesome's Avatar
I keep forgetting about that Joe, you guys like your 20A circuits. You don't see that much in homes here.
Old 02-17-14, 08:09 PM
markzrt1's Avatar
There is an egress window.
