Splicing existing unused range circuit.
Hi all!
I have a range circuit that is no longer in use due to installing a gas range. I now want to tap off of the existing 4 wire circuit and run a 240v line to my basement. The wire for the range is 6 awg aluminum stranded 4 wire two hots a neutral and bare ground. What do I need to do to make these connections? What kind of wire would be recommended for the extension run to the basement for 20 amp 240?
For the cost of the materials needed it would be easier to run a new 20 amp circuit. The aluminum connectors are expensive.
Well if I were to run a new circuit it would be very long as my panel is out in the garage on the farthest corner from where i am needing the outlet in the basement. plus my garage is dry walled so there would be the issue of fishing new wire through there.
Then you are going to need to install a permanently accessible junction box and splice the new cable to the old. I would suggest Polaris pre-insulated connectors. .
It will be used for a Amateur Radio Amplifier that says it needs 240v at 15 amps. I thought I would need the 2 hots and the neutral and disregard the bare ground? Is that wrong?
Well I ended up using a two gang box to make my splice in. I am using 10/2 MC armor wire as I have to run down a concrete basement wall. I used the split bolts for aluminum copper joins with the separator in the middle so the copper and aluminum wires never directly contact each other rubber taped,replaced breaker with 20 amp and I'm off to the races!
