EATON Panel and Breakers
hi all, i have breakers which don't RESET anymore with the TEST button, had everything tested and all works in the house, had electrician come out for troubleshooting/ making sure all is okay. (costly decision!!!! 2x companies, all said breakers are sensitive and just the way they are!) anyways.
my question is: looking at the pictures I have taken, what other brand, for example SIEMENS? can i install in the PANEL i have to replace these EATON sensitive breakers?
thank you all for your help and support in advance.
here are the pictures:
https://www.dropbox.com/sc/u9joi5rje6q65ox/E2l7srvfnL
You said they are too sensitive, what exactly is the problem you are having? You show both AFCI type breakers and regular Type BR breakers (and tandems) in your pictures, are you having trouble with the regular BRs too?
