Hookup wire vs NM-B behind walls
Old 02-19-14, 07:17 PM
I ran four separate 10 gauge 600 volt PVC insulated wires through conduit from one side of my garage to a junction box near my panel for a 220 VAC power source I need. I need to go from the junction box into the panel itself to connect to a 30 amp GFCI breaker I've installed. My question is this: Do I need to run NM-B wire from the junction box into the panel (behind the wallboard) or can I run the individual 10 gauge wires? The run length from junction box to breaker is about three feet.
Thanks ahead!
Old 02-19-14, 07:45 PM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
You can rule a cable or individual conductors in a conduit. Individual conductors cannot be used loose in the wall.
Old 02-19-14, 10:07 PM
ray2047's Avatar
You only need 2 wires plus ground for 240 (you don't have 220). You only need 4 wires if it is 120/240. What are you hooking up?
Old 02-20-14, 01:41 AM
F
Why not use some more PVC conduit into the service panel?
Old 02-20-14, 04:37 AM
Ray2047, I'm running a neutral as there's a control panel that manages the 240 load that runs on 120.
Old 02-20-14, 04:43 AM
Furd, it might be easier to run cable instead of conduit behind the wallboard. It's tight back there.
Old 02-20-14, 04:46 AM
W
Several kinds of cable you could run ( inside the wall ? ) . Or flexible conduit with individual conductors .
God bless
Wyr
