Using a 3 pole circuit breaker with 2 wires
Received 0 Votes
I have an enclosure with a 3 pole breaker but my house only has 2 hot wires, can I use the circuit breaker safely without any harm?
It will work well using the 3 pole (triple wide triple) breaker for a 2 hot plus neutral 120/240 volt circuit or even a one hot plus neutral 120 volt circuit.
Most likely the enclosure was or is for a 3 phase electrical system but you can use the phases individually (provided you have a neutral) or two at a time (for 240 or 208 volts depending on the system).
The disadvantage of using one 3 pole breaker instead of 3 single pole breakers is that if one circuit should trip its breaker, up to 2 other circuits (sharing the breaker set) will be flipped off too.
Be sure you have a neutral in the box before connecting up a 120 volt circuit. You may not use ground in lieu of neutral. Also measure the voltage between the chosen breaker terminal and neutral before connecting it up. In some 3 phase systems (240 volt delta) one pole will measure 208 volts to neutral and you never want to use that pole all by itself.
Yes, I want to use it as a main service disconnect. Yes there is a neutral bar.
zizanio
I forgot to ask in my last post, when connecting, should I connect the neutral first?
