How should I enter panel from exterior wall
Received 0 Votes
I am running power to a detached shop. I will be coming up an exterior wall with conduit and can't decide how to enter the box.
The box is flush mounted so I plan to punch a know out then drill out from the inside, but how should I connect the conduit to the box? Is there a fitting that I can terminate the conduit with on the inside of the box?
Received 0 Votes
If my understanding is correct, you need to effect a vertical-to-horizontal transition which is done with an "LB" fitting for your circumstance.
An "LB" is used for "close" " 90 degree turns in runs of tubing and conduit.
