200 amp service entry panel
Old 02-26-14, 10:52 PM
R
On a 200amp service entry panel----would the main breaker be two ganged 100amps, or one 200amp main breaker?
In other words, how much does each leg of the 240vac (120v---neutral---120v) deliver? If the total is 200amps, then it seems each leg would be 100amps.
Old 02-27-14, 02:10 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
Each leg will allow up to 200 amps to flow. It is not 100 per leg on a 200 amp service.
Old 02-27-14, 06:15 AM
ray2047's Avatar
That is wrong. It is 240----neutral----240. Each pole of the main breaker has 240 volts on it.
Old 02-27-14, 10:10 AM
R
ray2047: Thanks. My error.
