Light Switch Installation
Old 03-04-01, 12:56 PM
Guest
Changed a wallmount light switch and the old switch had three wire connections and the new switch only has two wire connections. When I changed the switch I left the ground wire unattached. The switch is correctly controlling the intended light in the room; however, the remaining lights on the circut are not operating. Is their any way of using the new switch (which is designed to operate the light)?
thks for the help!
Old 03-04-01, 06:18 PM
Wgoodrich
A switch that has three screws on it usually depicts that you have a second switch controlling that set of lights. Check you box to see if you have a red wire in that box. If you do then you will need to replace that switch with a switch that also has three screws.
The 99 NEC requires that you install the bare or green wire in the box to the green screw of the switch.
You are confusing on this statement. Are these lights also being controlled by that same switch. IF so then you most likely have a second wire that went to the switched side of your switch.
If these lights are not controlled by the same switch then you most likely have a power out in that box that is not connected to a constant power source.
All of the above should answer this last question.
Come back in with more info and we will try to get a little bit on the mark with our help to you.
Hope this helps
Wg
