How many couplings are too many- EMT?
Old 02-28-14, 10:04 AM
A
Running emt, had to make some bends and I am a novice and I used maybe an extra coupling or two a pro would not use....
Is that a bad thing since I depend on it for grounding? How many is too many?
Old 02-28-14, 10:13 AM
F
Whatever it takes to get the job done. No such thing as too many couplings.
Old 02-28-14, 11:19 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
As long as the coupling are tight the grounding will be intact. You could pull a grounding conductor if you are concerned if the pipe is large enough.
Old 02-28-14, 11:26 AM
P
Received 2,106 Upvotes on 1,885 Posts
More couplings are better than shaving off the wire's insulation or breaking a wire when trying to pull through too much at one time.
Old 02-28-14, 04:26 PM
Mr.Awesome's Avatar
^What Furd said.
I suck at pipe and a few times, in some crappy spaces, I've made a bend - couple - another bend - couple etc. to get it all to fit right.
Old 02-28-14, 07:22 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I suck at pipe
You just need more practice and maybe some instruction. If you don't do it every day you'll never be really good at it.
Old 02-28-14, 09:43 PM
Mr.Awesome's Avatar
Yeah thats half the problem Joe, my first year was mostly on a lift hanging lights. Very little pipework.
OP, I just re-read your post.
Couplings actually bite into the pipe when tightened all the way, ensuring a bond.
