replace 5 foot section of wiring in the middle of a run
Old 02-28-14, 12:06 PM
D
I damage a 5 foot section of wiring in my garage and want to replace just the 5 feet, without running all new wiring, seems a splice would work but Im asking for a more knowledgeable opinion, Thanks for your time, DCHANSON55
Old 02-28-14, 12:15 PM
G
Received 2 Upvotes on 2 Posts
Not a pro "sparky", but I think the usual route is to use two junction boxes, one at each good end and the replacement wire between them.
Old 02-28-14, 12:16 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
You can splice it...but you will need to have the connections in accessible boxes. You can't just leave them hanging in the open or in a wall. If this is between 2 outlets...best to replace the whole run between 2 boxes.
Old 03-01-14, 06:16 PM
D
I replaced the bad wire, used two boxes. Now the light switch wont work.
Old 03-01-14, 06:59 PM
ray2047's Avatar
Have you turned the breaker all the way off then on? Have you doubel checked all connections? It was cable not not individual wires, correct? Was it a power in cable, a switched hot cable, or a switch loop cable?
Old 03-01-14, 07:17 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
You screwed up. Now, replace all the wire between the two existing boxes like Gunguy suggested.
