Question outlets
Old 02-28-14, 01:47 PM
R
Question Question outlets
Just I want to know What is the minimum and maximum distance between outlets?
Thank you !!! for yours responses
Old 02-28-14, 01:49 PM
Received 1 Upvote on 1 Post
Depends on where you live. Different location can be different codes.
Adding your location to your profile will help in the future.
Old 02-28-14, 01:56 PM
R
I live in Ontario - Canada. The outlets are in the basement
Old 02-28-14, 03:32 PM
P
Are you referring to finished basement rooms ?
Old 02-28-14, 04:33 PM
Mr.Awesome's Avatar
Along a wall space, every 1.8m max. No minimum. You could put one on every stud potentially, or an 8 gang box with 8 receptacles. Small walls count as wall space too so long as they are at least 900mm wide.
I highly suggest you go closer with them though. Receptacles draw no power when nothing is plugged in to them, go nuts and put them in everywhere for your own convenience.
Old 02-28-14, 06:51 PM
Tolyn Ironhand's Avatar
Received 812 Upvotes on 684 Posts
@ Mr Awesome
Doesn't CEC limit how many receptacles you can have on a circuit? Or am I on drugs?
Old 02-28-14, 09:33 PM
Mr.Awesome's Avatar
Nope you're stone sober Tolyn.
On a 15A circuit you can't load the breaker past 80%, leaves you with a 12A load, each rec. and light fixture (if unknown load eg. a keyless lampholder) counts as 1A so you can only have 12 rec. per circuit.
But you can buy the biggest damn tub you can find and put 40 rec. circuits in the house.
