Reload this Page >
Square D 30A Disconnect Switch L211N -- Fused or Unfused -- Can it be Both?
Old 03-03-14, 09:55 AM
F
I see a small inside use disconnect switch, and it seems to be advertised by various sellers as Fused or Unfused. (Same Model)
What I am having trouble understanding is how the switch can be both.
Is it possible to configure the Switch to be un-fused (still using the existing service panel breaker) and then just use it unfused by the equipment being served?
Example - Easy way for anyone to shut off a seasonal use water heater where weeks pass by with out use -- and allowing anyone to use the switch right by the Water Heater rather than opening up the breaker panel.
I would prefer not to have both the panel breaker and switch be fused, just the panel breaker.
Your One Source L211N 30a Non-Fus/Indr Safety Switch - Amazon.com
Is the advertisement in-correct, or can the L211N be configured fused or unfused?
Old 03-03-14, 10:19 AM
Received 3,409 Upvotes on 3,059 Posts
I can understand your confusion because I'm confused too.
That disconnect is shown as a non fused disconnect.
Yet when you dig for the description is says.....
30A Light Duty Safety Switch, 2 Plug Fuse, Fusible, 3 Wire, 120/240V, Indoor Use Only.
It isn't just at Amazon... it's the listed the same way everywhere I've seen it.
I, personally, have never used one that can be both fused or non-fused.
Old 03-03-14, 10:31 AM
ray2047's Avatar
Not familiar with the switch but I wonder if there are jumpers that can be removed when used as a fused switch.
Old 03-03-14, 10:46 AM
G
Believe an un-fused one just has a pull connection to sever power.
Fused has round fuse harnesses on each side just in case of surge. U must put in fuses to work that don't exceed the disconnect's capacity (30 amp).
Either way, it's a matter of what's down the line you wish to protect. Lights, outlets and other minor stuff, no fuse protection. Sensitive electronics or pumps and such, always fused to protect your investment.
Old 03-03-14, 11:03 AM
This is a knife style disconnect. Not a pullout.
Old 03-03-14, 11:51 AM
F
Check This Link - bottom of page 3-2 (1st page) - seems to indicate "3 Wire - 2 blades and fuse Holders , 1 Neutral "
http://stevenengineering.com/pdf/45SAFETYSW_LD.PDF
Interchangeable ? (use either blades or fuse holders?)
Old 03-03-14, 12:36 PM
F
Looks like it is Fused Only, email reply from Square D :
The L211N is only available as fused. A non-fused version of this light duty
safety switch is not available. It is not possible to use it without fuses.
Old 03-03-14, 01:48 PM
ray2047's Avatar
Thanks for the word from the ultimate source.
Old 03-03-14, 05:29 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It's kind of pricey just for a water heater disconnect when an air-conditioning disconnect can be bought from a big box for under $10 without any shipping cost.
