#12 and #14 in same conduit?
Old 03-03-14, 11:00 AM
bigboypete's Avatar
Im running a 20A circuit for laundry. 2x12
I like to use the same 1/2" emt to run 2x14 for a 15A lighting circuit.
Is it bad practice to mix the gauges in the same conduit?
Old 03-03-14, 11:32 AM
ray2047's Avatar
Is the laundry in the same structure as the panel supplying it?
Old 03-03-14, 11:38 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You can mix conductor sizes in the same conduit. An EGC, if run, needs to be sized for the largest circuit.
Old 03-03-14, 12:20 PM
bigboypete's Avatar
Yes laundry is in basement and lighting circuit is also in basement both supplied from same panel.
Is mixing the two atypical? Would this be considered sloppy work or wouldn't pass the inspection?
Old 03-03-14, 12:53 PM
pcboss's Avatar
No code issues as long a conduit fill rules are observed.
Old 03-03-14, 06:46 PM
Tolyn Ironhand's Avatar
Received 868 Upvotes on 731 Posts
Mixing wire sizes is done all the time. You should group the wires of each circuit (hot/neutral, hot/hot, ect.) together with tape at each junction box.
